** HAVN BF 360 SOLID - LOW KEY, FOCUSED AIRFLOW **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
OcUK Staff
8 Aug 2007
Hi Gang
Following the launch of the HAVN BF 360 last year, we have seen huge demand from performance hardware enthusiasts looking to take advantage of the high airflow properties offered by this innovative chassis design.
The BF 360 offers tier one airflow performance with comprehensive AIO compatibility. The high airflow design paired with the GPU focused airflow guide ramp on the foot of the case provides exceptional cooling performance when paired with the dual 180mm fans at the front of the case.
Following the launch of BF360, HAVN got a huge level of feedback showing demand for a solid side panel version.
HAVN has now expanded the lineup with the BF 360 Solid. The same high performance case, now with a cleaner, more premium aesthetic.
For existing BF 360 owners, the solid side panel will also be available as a standalone purchase too!
looks like an air con unit with the fascia material made from 1970s public toilets ... yup im old
I launch a case with RGB - I get told we dont list any sensible looking cases.
I launch a clean, sensible looking case, you lot say it looks like an air con unit.
make your bloody minds up. :p
Look, if you can't handle the duality of man then this career may not be for you.
I really like this no-fuss clean case, my only problem is that I already have the LL Dan A3 and it's doing everything I need from it! It's on the list for future though for sure :cool:
I've got the black one with a window at home, the best case I've ever owned, maybe bias coming from me, but it's the honest truth. :)
i just cant make my mind up ... i dont really need a case ive got the phanteks xt pro which i got on here for £24 b grade.. Phanteks higher end stuff seems to be a bit too bling.. and the server stuff is only now available with solid side panels
knew i had seen it before :p
