A few people have said this case is the best case of 2024, which is quite a statement considering we're near the end of the year now.
Hi 5UB,
These look great. If and when HAVN do a V2 of these cases, or new models, more USB ports might be something to suggest for consideration.
There are certainly more products in the pipeline, there's currently 3 USB ports on the top of the case (2x USB-A and 1 USB-C), how many were you thinking?
3:48 - So does this mean the HAVN HS420 is an Overclockers own brand case?
Yes and no, the HAVN brand is part of Pro Gamers Group, which is the same company that Overclockers UK is a part of. But Overclockers UK themselves are not the team putting this case together, it's a separate team. However, Overclockers UK have had some input in the development stage as a system builder.
The front usb and power are on the top right, looks to be 2 X USB A and 1 X USB C
Correct.
I like the idea of a bottom rear fan, it's about time a case had one in that position. It's not a case I would consider though. At the end of the day it's yet another Lian Li 011 clone with a couple of tweaks and there are already enough of these lookalike cases.
It's a very unique design, this case certainly has a lot of features which sets it apart to other "fishtank" cases, not just the bottom fan, but the cable routing system behind the motherboard tray, the cable grommets, the panoramic glass, the air guide glass, and the entire structure of the case is unique in terms of the ventilation and cooling, HAVN developed the case from the ground up and is not a clone or a copy of any existing case on the market.
They do look very nice case's,past few orders from Ocuk I've had one of those slips inside and has this case advertised and each time I'm like oh that's nice!!
If I hadn't of purchased a new case like 3 months ago if have snapped one of those up.
Glad to see the leaflets being noticed.
Mine just arrived! looks amazing. Will be doing a build log on our channel once we get the new intel CPUs in
You're going to be very pleased with it!
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
