HAVN HS 420 and HS 420 VGPU Case
A few people have said this case is the best case of 2024, which is quite a statement considering we're near the end of the year now. :)
There are certainly more products in the pipeline, there's currently 3 USB ports on the top of the case (2x USB-A and 1 USB-C), how many were you thinking? :)
Yes and no, the HAVN brand is part of Pro Gamers Group, which is the same company that Overclockers UK is a part of. But Overclockers UK themselves are not the team putting this case together, it's a separate team. However, Overclockers UK have had some input in the development stage as a system builder.
Correct. :)
It's a very unique design, this case certainly has a lot of features which sets it apart to other "fishtank" cases, not just the bottom fan, but the cable routing system behind the motherboard tray, the cable grommets, the panoramic glass, the air guide glass, and the entire structure of the case is unique in terms of the ventilation and cooling, HAVN developed the case from the ground up and is not a clone or a copy of any existing case on the market.
Glad to see the leaflets being noticed. :)
You're going to be very pleased with it! :)
just waiting for the core ultra 285k to arrive! any ideas when they will finally be landing in the UK?
Yes the leaflet came with my new motherboard, so went to check it out.
Very pretty, wish I had a use case for it. I run 2 360mm radiators and this seems very good if I want to show it off with RGB fans, but right now satisfied with my no window build.
Just only built my mini ITX Terra build, I cannot justify another build.
@fiveub Case looks great. Do you know if the VGPU kit will be able to be purchased separately if you'd wish to in the future to add to the base model or are the constructions entirely different? Cheers
We plan to release a VGPU kit separately, hopefully in the coming month. :)
@fiveub Any change of the discount code being reenabled to get the vertical case for same price as the horizontal? Went to order earlier and looks like it's been taken off :(
Hey,
Unfortunately the discount code for that promotion has now expired, and we’re unable to re-enable it. We understand how disappointing it can be to miss out, but we’re confident you’ll find the case is worth every bit. :)
