have you taken off the top panel where the 200mm fans are, you should see some bars and those should be used
You just need to take the stock 200mm fan off and use the holes that are designed for the 120mm fans. You only need 4 screws to hold the rad on
I'm guessing my warranty shall be void by user damage but I have no idea what I did wrong
