When do you think it will be finished by?
Google chat later
anyway, filling didn't go to plan and there were two leaks. There is also a problem with the block I have emailed EK. how are they for their CS?
What problem did you have with the block?
The rubber ring n the inside was ripped. I have emailed EK. how ate they for CS?
.... you really haven't been very lucky
Good luck with the returns =D
Were your leaks just on barbs and the block? Unlucky mate![]()
yeah the warranty sticker is usually on the side of the block, if it's not there they may refuse warranty I suppose
can you get an O ring to replace it from anywhere, saves time and messing about
omg im soooo jelous i really want a liquid cooling setup like this but am on a really tight budget anyway i can do a cheaper setup to this for under £100?
Looking good cleeecooo, have you done water cooling before? Fingers crossed you get a better bit of luck when you get back to finishing it off.
Not worth it. Dk it properly or not ar all£200 is a realistic budget.
You could always try one of these, Mr Dubs speaks very highly of the kit, I'm thinking of using the same..
http://forums.overclockers.co.uk/showthread.php?t=18255454
