Hazro HZ27WC 8-Bit 27" Glass, Condensation problem.
19 Jul 2004
I bought this monitor yesterday and going from an old dell crt i was well impressed with it BUT after 20 minutes or so when its warmed up there seems to b a build up of condensation behind the glass, its my first flat screen monitor so before i start the process of getting a replacement i jus thought id ask on here if this is normal for a new monitor of this type and will go away on its own with a little time or if there is a simple solution that will not void my warranty and could i damage it by continuing to use it?
Cheers.
are you in a very cold room ?
condensation is created from heat meeting cold and moisture in the air turning back to water
well i have a digital clock with a thermometer built in its only a cheap thing so not sure of the accuracy but it reads 18.3.
im not really sure how cold that is for a room, (or if that is even the problem)
how long did you leave the monitor on for ?
all i know is for condensation to occur there has to be a temp difference on each side of the glass....
wonder if anyone else with this monitor had the same thing?
well its only a day old and the first time i had it on for just over an hour then noticed the problem so turned it off, next time i tried to leave it on for about 3 hours to see if it would go away on its own. i youtubed the problem and saw a video of someone using suction pads to remove the glass on an apple screen and wiping the condensation away but i dont wanna fiddle with it and ruin my warranty.
no . wouldn't suggest trying to take the glass off
i would speak to oc'ers tomorrow and see what they say
If it's only a day old I'd leave it a couple of days, it's probably been sat inside a cold depot overnight when being delivered.
yeah with Glass version, I would have left it out of the box over night. That way it gets to room temp.
Same as when you get a new fridge/freezer, you are meant to leave them inplace for some time to let the coolent level out.
I collected it from the store but yea i know what your sayin could have been cold where it was stored, ill leave it for a few days like u say just to see if it goes away, its been on for 30 minutes now and so far no sign of it so fingers crossed.
Cheers for your time andy/paul.
Ok that makes sense, and its been left overnight now and does seem to be ok so far but its only been on for about 30 mins.
Cheers mate.
