Hazro HZ27WC Power cable replacement + HDMI/DVI-D Adaptor
Permabanned
8 Nov 2003
Yorkshire
1) Having a bit of an issue finding a replacement power brick for my Hazro HZ27WC 2560x1440p monitor, the sticker says a 24V / 5A 4 pin.
I just bought a replacement 4 pin power adapter from amazon without realising the monitor needs 24V / 5A which resulted in the 12V /5A I bought not working.
Yet now I'm finding that the positive and negative poles are in alternating positions on different 24V / 5A cables, and I can't find any manual online to say which ones I need.
2) This is a dual link DVI only monitor. The FE 1070 only has one DVI-D connection which I'm using already, so I bought a HDMI to DVI-D adaptor (This) Would this even work in the first place or should I give up now?
The HDMI -> DVI-D should work fine - I used the same thing on my hazro for years.
I've got the HZ24Wi, which is a fair bit older, but AFAIK they use the same adapters. I bought a dodgy one off amazon which worked but was awful... but the one you want is LiShin 0227B24130. Good luck sourcing one :/
I've tried the HDMI / DVI-D adaptor on my other monitor (Korean 1440p import) which is also DVI-D only and it doesn't work, may still work on the Hazro?
I can find lots of generic chargers, yet I'm unsure on which I need as they all have different polarity order. Even googling the LiShin, there are ones with positive and negative prongs in different positions.
I just tried the HDMI/DVI cable on my laptop (HDMI ouput) to my Dell U2412M (DVI) and it worked fine. Also works on my Hazro.
To be honest, I don't think the polarity matters. I'm 90% sure I was sent a replacement power brick by Hazro under warranty which had opposite polarity on the pins to the original one. The one I have now matches the replacement, so can't actually test both for you :/
Another option is to buy a generic 24V / 5A power supply and cut the connector off and replace it with the one from your broken one. Obviously a bit dodgy, but if you do it properly and then shrink-wrap the join it'll be fine.
Got a power cable working, yet the DVI-D to HDMI adapter doesn't work.
Googling tells me that these adapters only work up to 1920x1600 resolution, so this 2560x1440 monitor wouldn't work with a hdmi adapter. Oh well, to the bin this monitor goes.
