HD 4890 High temps and artifacts
19 Feb 2010
Just got a "new" XFX 4890 and with all the latest drivers i decided to run MSI Kombustor. I found the card idling around 68-70 C and when under load raising to around 88-90. Fan speeds reaching around 66%. When i ran the stress test i noticed a lot :eek: of artifacts on the screen. No instability yet though. Is this normal and if not what should i do?
Cheers.
If its anything like my xfx, the card wont run stable at its default clock of 870 core. System will freeze with a grey screen eventualy, so I force it to 850 clock (4890 ref?) in order for full stability. Its a non reference card, no active cooling on the memory, so no overclocks possible without replacing cooling.
Yea I'm thinking it is pretty much the same. I have just ran ATI autotune to see where that though was best and its basically just underclocked the card. Not too happy with having a poorer card then what I pay for. Might send it back and upgrade to a 5830. Thanks anyway. :)
