hd 5850 driver problems
8 Apr 2009
Tavistock,Devon,England
tryed to install the lastest drivers for my HD5850, installing them and the screen went blank left the pc for 10mins then restarted it, now the pc will not start unless in safe mode tryed to install the drivers again and it says "failed to detect system config" tryed to uninstall the drivers and it says "failed to load dection driver"
how can i install the drivers? i am sticking with the green team next graphics card ATI/amd drivers suck!!!
Should be in the graphics card section :D. If your not using the disk drivers, then give it a go to see if it just the software.
not fine about 1 hour after this with all my stuff backed up same problem... i have formatted the hard drive and reinstalled windows, same problem i have to use safe mode just to get into windows itself... really need help here?
cards been RMA`ed, problem with the card rather than drivers same think happens in another computer and other cards work in this one... so i am using a 8500gt... :(
thanks for you help anyways
