Heya
HD's are the one component of a PC I know very very VERY little about, and as my 80gb Maxtor is on its way out I need to replace and/or upgrade... so I need help!
Original Plan: Buy 2 Seagate 80Gb drives 1st for windows/apps 2nd for storage
2nd Plan: Buy a 74Gb Raptor and just chuck more onto DVD
3rd Plan: A 36.7Gb Raptor and 120gb Seagate
It would be for games mainly - my present HD is really holding up load times at the moment! (X2 3800+, 1Gb Geil, 1800XT, etc) and I usually format my main HD every few months so a big windows/apps drive isn't THAT important...
- How much faster are raptors? Worth it?
- How much noisier?
- Which plan should I go for?
Cheers!
Chris
- How much noisier?
Cheers!
Chris
