- 20 Feb 2004
- Nottingham
Hey,
My system is getting pretty dated now, but still runs everything I use pretty well. I use it mostly as my DVR and media center. I've got two 36GB 10,000RPM Raptors (Raid 0) and an IDE WD 80GB HD running.
The problem only just started the other day, and seems to really get worse when I watch recorded TV, and sometimes not even show. I can hear from inside the PC that "loading" or "booting" sound hard drives have when they first boot up, and a second or two after they do so, the system freezes (completely, can't even get the "Num Lock" light on the keyboard to change). It stays frozen for maybe 10-20 seconds, and then returns to normal. This happens over and over at random intervals (or so it seems).
My first course of action would normally get inside, unplug the 80GB drive, and see if it goes away. I've been a bit lazy and just wanted to see if anyone knew of this problem or had some ideas before I get down to fixing it.
Thanks!
P.S. The OS (Win XP SP2) is on the raptors.
Thanks!
