HD to SSD question
23 May 2006
Current HD is partioned into windows, documents and steam.
If I put in a SSD and install a fresh windows, do I simply unmount the partition on the existing HD holding windows?
You have two options really:
1: Install Windows to the SSD then format the old Windows partition.
2: Create a backup image of the Windows partition then restore it to the SSD. Then format the old Windows partition.
My preferred choice would be 2. Plenty of software out there that will do it such as Macrium Reflect. The big advantage is not needing to reinstall Windows and all your applications.
The big disadvantage is you may have to do some tweaking to enable the SSD features in Windows [assuming Windows 7 here].
Obviously this will only work if the current Windows partition is smaller than the SSD!
Yep Windows 7 64bit
option 1 really, ssd is 60gb, current windows partition 240 gb ( i luve the games)
So
unplug HDD,
plug in ssd,
install windows,
plug in old HDD,
go to disk management and unmount windows partition
create new partiton out of old windows one
bob's your uncle and all that.....
That right?
I would perform the following.
1). Locate all of your game save data and back it up.
2). Install a fresh OS onto SSD and reinstall all drivers and apps.
3). Reinstall games onto the partition/hdd of your choice.
4). Copy game save data back.
This may take a few hours but you will have a nice clean install that will maximise you system performance.
cheers mate, backed up my stuff just in case and will do the SSD thing next 24 hours.
If you don't hear from me again...it went horribly wrong :D
Doing the same thing in a couple of days. My plan is back up all my saves/program data then format. Install Win7 on SSD and spend all day reconfiguring :( Thank god I save all my install.exe's lol
