HD2600Pro - video hardware acceleration, how?
Don
21 Oct 2002
Parts Unknown
As title.
I've had this for a while in my htpc, want to make sure I'm fully taking advantage of it. I have 9.2 cats and the AVIVO thing
Currently I use Vista32 MCE, with Vista Codec Package installed.
Will I be getting hardware acceleration from this with, avi, mpg, mkv, dvd and (yet to buy) blu-ray discs?
What do I need to install to take full advantage.
I'd like to have it all enabled in Vista Media Centre
Its really difficult to get hardware acceleration working. All the codecs are commercial. The Cyberlink Ati H.264/AVC/VC-1 codec is the only one I know that works, but it doesn't seem to use any less CPU time than software only codecs when played in KMPlayer.
If you can get PowerDVD to play a high definition file expect next to zero CPU usage.
Basically it depends on the media file, if its non-standard then only software codecs with high CPU time will work. Only the display driver is needed for cyberlink to work. The AVIVO software is for encoding I believe.
give 'media player classic - home cinema' ago, works great for me on my nvidia card, check the 'dxva' link on there homepage for information on how to enable hardware acceleration, not sure if this will integrate into media centre though
http://mpc-hc.sourceforge.net/index.html
