HD4870 Noise issues!
29 Dec 2009
Germany
Hey,
Is there any way to turn the fan of my Sapphire HD4870 to extremely low levels? I want to be able to sleep with my PC running, however the graphics card alone (everything else is virtually silent) prevents me from getting any rest whatsoever.
I'm using RivaTuner to clock it, with the PowerUser settings tweaked to allow me to set any value for fan speed. However, even when underclocked to 375/450 MHz and with my fan speed duty cycle running at 0-5%, the fan is about as loud as my old CPU stock cooler + PSU put together.
If I remove the card from my setup I can confirm that there is absolutely no noise whatsoever apart from HDD activity.
So I'm asking: Is there any way to mod the fan to run at stupidly low levels for when I'm sleeping (speed is not an issue, I don't mind the noise when gaming)?
Otherwise, I've seen that there are GPU coolers available for as little as $15 in my area. Should I bother trying some of these, or will a cheap GPU fan be even louder?
I don't seem to be able to lower the fan speed using afterburner any lower than I can using RivaTuner.
Might it be a driver problem that I can't lower it "below" 0% duty cycle? Ie. 0% duty cycle is still pretty loud.
