Hi, i have got a Fujitsu Siemens Scaleo P pc. I bought at the end of 2005 and 3 months in i had a HDD failure. I got a new one under thw warrenty then 9 month later that failed. I had to buy a new one then 3 months later that failed. I'm currently on my 4th and its making a clicking noice just like the other when they were about to fail. It takes for ever to load at the windows xp screen (much longer than usual). I have only had this HDD 3 weeks! I took the pc into my local shop and they did tests on the CPU and PSU etc and they all passed and that it was a faulty HDD but 3 failures and maybe a 4th is a bit too unlucky. My temperatures are (high 30s to low 40s). Do you know why this is happeneing?
, well ide hdd's use 5 & 12 volt and sata's 3.3,5 and 12 volt then.
