- 20 Feb 2009
- Stafford, Staffordshire
2 different hdd in 2 different SATA ports have now "crashed". They stop working and appear to of disconnected from the pc. Restarting doesnt usually fix it. But shutting down waiting a few moments then booting up usually does.
Could this be the infamous SATA port problem with my motherboard? The drives only have program files on. When my first drive (D:/) started failing I moved my regular programs onto a spare, unused HDD (Y:/). But now that has the same symptoms.
I should also mention, I had 2 blue cold cathode tubes hooked up, and when i replaced the D:/ SATA Cable and booted up, the cable for lights heated up and melted the plastic covers around it. I turned it off quickly, checked for other cable damage and removed them both from the system.
can anyone offer some troubleshooting tips? system specs are below in my Sig.
