- 27 Jun 2008
Hello,
I have a 2tb ext hdd made into 3 partitions. The first two I can write too ok and save files. The largest ntfs partition "1tb" I cannot seem to fix. If i try and write files to it it will stop copying them over after a minute or so. Scandisk stops almost as soon as it starts off. I have tried deleting the partition and creating a new one and and also re-formatted etc but the problem still persists. Is there anyting else I can try to make it usable again ? I dont think the hdd is totally corrupt else I wouldnt be able to use the other 2 partitions which are ok. Any suggestions would be helpful. Carl
