Hi
My uncles HDD is a 1TB Seagate that is about 4-5 years old, it is taking ages to boot up and i cant fathom the problem? it takes well over 2 minutes from button to desktop, mine takes about 30 seconds.
the rest of his set up is old (but still usuable) though: Quad-Core 8200 @ 2.6Ghz / 4Gb 800Mhz DDR2 / Chipset GPU / Gigabyte mobo / Win 10
I have used PERFECTDISK as I find it to have the better placement algorithm, it places boot files contigously at the start of the disk, now i have ran a few passes, consolidate free space, defrag then optimize in order just for good measure and its still the same.
the only other thing of note is it will NOT perform a boot time defrag for some reason, i set it in PD but nthing happens upon reboot, and im wondering if some of the boot files in use are in the page-file which might be heavily fragmented...i dunno... the size of the page file is fine (Managed by system) changed that to 6Gb but still same results.
I used a SMART reader which respots health generally OK but has some concerning high numbers in certain readings
DESCRITPION - RAW VALUE
CRC Error Count - 1812
Seek Error Rate - 356377508
Command Timeout - 38655295514
Raw Read Error Rate 113624787
Hardware ECC Recovered - 113624787
Head Flying Hours - 204096845925773
High Fly Writes - 2
Reported Uncorrectable Errors - 5
no reallocated sectors....
could anyone offer any advice on this please?
thanks
High Fly Writes - 2
thanks
