HDD Rack inside case - some help?
18 Oct 2002
Pentonville Prison
Have decided that I don't want a massive server case and hence need to fit my HDDs inside my Coolermaster RC341 case. There is good space with a 120mm fan sucking in cool air and two sets of mounts helpfully placed. What I need is a set of brackets that can be attached to 5 HDDs and then to the mount(s) so that my HDDs can hang in place to be kept cool.
I don't have a steady drill hand (no, I am not suffering from alcohol related shakes) and wonder if some kind member could help me out on the construction side.
Or better still is there some product (a bit like meccano) that can be used to bracket HDDs together?
Thanks!
