Hi all.
I have aS eagate 200GB HDD, got it about 2 months back from the Clearance section on OCUK.
Anyways I turned my machine on last night and it said something about the disk failing and to backup.
I pressed OK and it booted into Windows fine.
I've just turned it on again now and the same thing happened.
Is it going to die on me? It's only a couple of months old surely it should be fine.
Thanks!
Thanks!
, get the serial number on the drive and check the warrenty status
