Hi guys,
I got a small (big) problem and I hope you can help me with it. I got a 500 SSS drive where I installed Win7 (this is a working disk). Then I have 2x 2TB disks also that I only use for storage. These 2 disks are split into two partition each has roughly 930GB. One of this partition is failing on me ( Im guessing the whole disk is failing then) When I open that disk I can see the folders however when I try and open further it freezes (ALWAYS - I tried numerous times and it does it every time). For better understanding let`s say that my SSD is drive A, my HDD 1 has 2 partitions = B and C, and HDD 2 has also 2 partitions = D and F - will use this as a reference. I run diskcheck fix and repair over night and it repaired a lot of indexes and there were lot of orphaned files etc however I did not fix the problem. The partition that is affected is partition B so I am trying to copy what I can into the other HDD 2 (that I believe is OK). I have copied almost all I could, then I powered down and disconnected that bad HDD 1 and restarted, but the system did not boot and I got that message that I need to select a correct boot drive (cant remember exactly what it was) and had to power down again. then I connected that HDD1 back up and disconnected HDD 2 and the system loaded up normally...? What the hell?? I am attaching a screen from disk management what it looks like - something weird happened to my drives. One of the partitions is showing 1.7GB free of 930 GB??? I need to put this back somehow and Im not sure what to do without damaging the date etc. I want to have the SSD with system bootable drive and the other disks just as a storage? Can anybody advice what to do and how to do it?
http://postimg.org/image/crujm7yg9/
Many thanks,
Tom
Many thanks,
Tom
Do make sure you've got a backup of everything on your SSD as you could end up being forced to do a reinstall.
