Is the HDMI device the default audio device?
hat it definitely is?Control Panel -> Sound -> Set default (After choosing the device you want as default)
yes its always been default
Is the HDMI onboard or on a card.
Nvida / ATI ??
Hum, same card here and no problems.
Which HDMI drives are you using?
Sounds like your just using the default crappy windows ones maybe.
Try the new catalyst 9.3's as they now have the HDMI driver as part of them.
Tried turning the acceleration down to basic, its what i had to do to get sound in Crysis.
