Hey i wasn't sure what forum to put this in so if i've chosen the wrong one sorry. Basically i have a 7950 graphics card and the BenQ G2450HM 24" monitor from OC, which i know can be connected together using an HDMI cable.. but when i tried this the monitor was stating that there was no cable found. I had a look at it and it looks like where the HDMI cable goes into the 7950, the HAF X case that i'm using is jutting out a little too far from the cards connections to allow my HDMI cable all the way flush into the slot in the graphics card. I hope i explained that well enough? I took a pic to show it clearer..
As you can see, it's just not leaving enough room for the HDMI to go in properly. I thought at first that it was in far enough but i guess it can't be if the monitors not picking it up, and the HDMI cable that i have has quite thick casing which isn't going past the edge of the case. This is kinda a bummer, so i was wondering if anyone knew of any HDMI leads that have a longer end on them or a slimmer casing? Otherwise i suppose i'm just left with having to use a DVI connection instead. (i'm using a dvi to vga connector at the mo because my other dvi to dvi lead broke)
