HDMI/DVI to scart?
20 Oct 2010
Scotland, My home.
Dont know where to put this but is there any trusted brands that make DVI or HDMI to a scart connection?
My 42" pansonic plasma tv is veryvery old and has no HDMI or DVI. There are DVI to scarts but are mostly chinese crap.
Anyone have any suggestions?
I havn't seen any cable's or adapters that do it, only small converter box's that can take dvi+hdmi in one side and output scart the other for around £40.
Edit: Does the TV have RGB phono inputs with Left/Righ Sound? I've seen a lot of hdmi/dvi to phono's!?
yes it does. but i dont know how that works!
Since SCART is limited to PAL TV format 720*576 (plus maybe NTSC or Seacm depending on the TV) it would be hard to tell a good from a bad output. Doesn't your graphics card have a S-video output?
yes it does i think. is that the small round connection beside a DVI? i have a 460gtx which doesnt have it but i have a card that does.
It's a round connector around 1cm in diameter with lots of pins.
can easily get a card with one of them. But i dunno if my tv has that support, will have to check sometme. all i know there is 1 scart connection left, and those RBG connections which i know nothing about.
Does your t.v. not even have a VGA input? I used to have a tevion non HD plasma and that had a VGA input and that was many moons ago.
can easily get a card with one of them. But i dunno if my tv has that support.
S-video and SCART is like DVI and HDMI; the connector is a different shape but the signal is the same.
You can get a SCART connector which have a S-video connector, composite input and phono L/R on the back.
Not quite the same. Depends on source, S-video or RGB or both signals in the SCART output.
Main issue is the two signals are in total different domains. Digital to Analogue. It would be easier to feed a VGA signal to RGB-SCART as the signals aren't that different. And I would have thought there a good chance of using VGA to those RGB (Component?) inputs or even an RGB enabled SCART.
Check you graphics cards outputs maybe DVI-I (VGA) to component, or the mini DIN adapter that came with it to component.
Unless marc has an old ATI card and is handy with a soldering iron then digging up the old 2004 trick of getting an RGB input from a computer to TV is not relevant.
A TV without DVI/HDMI/VGA is likely to have component inputs, the only problem is that any the only cards which supported direct component output was a native ATI X600 card which did not work properly or the optional ATI dongle.
All the options for getting a HD signal to the TV is likely to cost a least a 3rd of new TV
Some of the old Plasma could accept RGBHV directly. Combining the sync is more than being handy with an iron. There were ready made RGBHV to RGBs/RGsB synch adapters around in the day. I'm not suggesting he'll get anything like HD, I'm suggesting that he remain in the analogue domain for any likely solution. Didn't HD4850's have encoder chips for ED/SD TV over component? OP, see if you can determine the type and maximum resolution/interlace/frequency the 'multi' input can handle and work back from there. Or personally I'd just use it as an excuse for an upgrade.
i did it somehow with our old telly, but i cant really remmber too much. it may have been dvi > vga dongley thing u get free with gfx cards, then a vga lead which goes to component or s video, to finaly a scart adapter, scart end into tv, s video/composite end plugged in as needed
old crt, tv/video looked fairly good, but omg was text in windows horrible
just found out the name of the tv. Its a Panasonic TH-42PX25U. there seems to be 2 models, one has HD and other is very basic. Cant find the basic one (mine) but i will keep looking.
when i find spec edit this post :)
