Wasn't sure whether to post this in the 'Monitors' or 'GPU' thread.
I've just completed a new build with following spec:
Corsair TX650M power supply
MSI B450M PRO-VDH MAX motherboard
AMD Ryzen 5 3600 AM4 CPU
Intel 660p series 1Tb M.2 SSD
Gigabyte DDR4 16Gb (2 x 8Gb) 2666 MHz RAM
Gigabyte GeForce GTX 1050 ti GPU
Windows 10 Pro
I was able to build this, boot to BIOS and install Windows 10 pro using a Philips monitor from my main PC (via HDMI).
However, the new PC has been built to replace an elderly PC that I use with a Viewsonic VX4380 monitor, and this is where I have encountered my problem. I have tried connecting the new PC to both HDMI ports on the monitor, but with both ports I get a 'No signal' message on the monitor when I try to boot up the new PC.
Whenever I boot up my old PC (using an old Radeon card) and the same HDMI cable, I get a perfect signal on the Viewsonic monitor.
Can anyone suggest why I get a perfect signal on the Viewsonic monitor using my old PC, but no signal from my new build (with GeForce GTX 1050ti card) with the same HDMI cable, when the new build PC works perfectly via HDMI with my other monitor (Philips BDM 3270).
I'm struggling to come up with any ideas. Any help would be much appreciated.
Windows 10 Pro
