HDMI Problem (When Changing Source)
15 Aug 2003
Essex
Hi All,
Just put a HTPC together and using an onboard AT HD3200 card via HDMI it is working fine, except one thing, if i change the Source on the TV (Samsung M87) when going back it can't detect the output and the PC needs to be manually restarted for it to "re-pick up" the signal if you will.
Anyone know a setting/work around for this?
Cheers!
