HDTV CRT in the UK
willd58 said:
Im finding that one quite hard to believe, any idea what its guna be like as a second PC monitor?
I imagine the dot pitch will be aimed at doing 720p, so if you fancy running your PC at 1280x720 on a 32" screen then fine, much higher res and it'll look carp :)
1280x720 doesn't look bad on my 77" projector ;)
MB
Nice, i nearly bought a 32" crt yesterday actually but decided to wait a few more months, good job i did.
Its a Samsung CRT - it will be horrible.
The last slimline crt they dod was the most unreliable tv in the history of tv's.
It also does not look like it will do 720p
It has to be 720p or they cant call it hd.
Thi isnt their previous crt either im sure itll be great.
Only the reg are calling it HD-Ready
So your saying that every crt that samsung have made to this point (and they have all been terrible) counts for nothing and that this new one (in a range that is horrific) will be instantly great ?
Matblack said:
32" HD for £350 :eek:
That'll be going in the living room then!
MB
Yep, if they're that price I'll be buying one straight away to replace my ancient CRT in the living room.
Ohh and id like to point out im all for HD-CRT's, as ive said in the past the best image ive ever seen was via a HD-CRT projector.
However i dont see such a cheap CRT being any good - look at the last Samsung slimfit - it had terrible geometry problems and was not able to display football (well technically it could but it made a right mess of it)
Lets hope its good, just id keep the champers on ice ;)
hmm my sister has the slimline samsung CRT in her house and it displays the football fine and has a good picture?
some lcd's i have seen displaying football... dont go there lol
Hell I'll be replacing my 27" LCD at that price. Native HD on a CRT must look amazing surely
EDIT - Thinking about it, maybie this is just HD compatible not ture native HD, hope I'm wrong tho.
If that's really going to be £350 I'll have one!
Need something to replace my Philips 28" and would prefer to go CRT as LCD looks pants with freeview / sky.
After some searching around the USA Samsung TX-R3081WH - 30" and cheapest at $699 or £399.
Uk spec tv - remember has to do 50+60hz with a 2" bigger screen cheaper than the USA price - i think not.
Something does not compute.
US screens are measured using viewable sizes- so 30" == 32" here.
I'm tempted by one myself. Got a panny tx32pd30 here at the moment and its a damn good screen so i'd have to test the sammy first though.
