Head Gasket Repair Diary
  • Thread starter Thread starter M0T
  • Start date Start date
Argh!
One of my Allen key bits snapped off in the cambelt tensioner, I tried everything to get it out but to no avail. I have just hand to cut the whole bleeding thing off!
I have coolant loss. It appears to be leaking from the waterpump area. Looks like the belt has to come off again :( :mad:
Liverpool-Lad said:
You did renew the cambelt, right?
We've covered this, 500 mile old cambelts do not need to be changed unless there is an obvious problem with them.
The water pump is only 500 miles old and should not be leaking either.
Well at least the car still runs :)
Liverpool-Lad said:
Cambelts should always be replaced as they are tensioned when fitted. Its up to you though.
And I tensioned mine when refitting it...It would have been impossible to fit the belt back without tensioning it properly.
But they should only be tensioned ONCE. Like I say, its up to you - but itd be a pity for the cambelt to let go after all your work for the sake of a tenner.
Who says that?
The rover workshop manual I have says its ok to re-use and retension the belt.
Edit: I clarify that according to the workshop manual it is ok to retension an existing belt if it has been completely removed from the engine, which it was.
I know that the garage that I use to do all the work on my MG with the same engine change the cam belt whenever they have it off the car for any reason. It's only a few quid for the part so why not change it and fit a new one. I don't know if they'd change a 500 mile belt though.
HT
I'd just change it for the sake of ten quid. I made the mistake of not doing it on my Uno whilst doing the hg, and it went within about 500 miles. But like they said, your choice;).
Who says that :confused:
They are 'tensioned' everytime the engine starts due to the 'kick' of the starter motor
