Very nice and easy adjustment there, we could use your menu, with a simple drop down for the piers, i've made a basic drop-down for piers links...
Will post shortly once it's functioning correctly...
EDIT::
snip
Excuse the poor quality JPEG.... and ignore the fact it's a very basic image (it's simply just to show you the menu)
Basic dropdown for the piers that i've made, it could be used in for the menu in Mattus's pic above....
A few lines of CSS and a little bit of HTML...
We could add some icons, some transparency, backgrounds with hover effects...(or whatever you like).... the possibilities are nearly endless....
EDIT 2::
Updated image... transparency used with menu
You can't see the cursor in the screenies (just the app i use for quick screenshots and cropping)...
