Headlight Restoration kits
Superb, I use Peek metal Polish on my RX8 just rub in for 10 minutes per light... gives good finish, however nothing is like using a rotary and polishing them!
I used the Meguiars kit on some (almost yellow) headlights on my car last night.
I was very impressed with the results. Recommended for sure
As said don't bother with a specific overpriced kit; all you're doing is refinishing plastic.
What you are actually doing is completely removing the damaged anti-scratch UV resistant coating to expose the softer polycarbonate underneath. You can make it look like new, for a while, but nothing you can apply to the plastic will provide the same level of protection.
Unless you buy a dedicated UV-resistant coating, offered by say, 3M? :D
