- 31 Dec 2013
- Kent
Hey guys, I'm currently after either a pair of headphones or a headset, predominantly for gaming, as well as a bit of music and personal editing on the side.
My budget is £150 maximum, ideally they would be under £100. I don't want to have to buy a DAC or an amp to power them, just want straightforward audio.
I have an X99 deluxe V1 which they'll be connected to, mainly for use on my pc but I also have a PS4 and potentially the Nintendo Switch in the future, so it would be amazing if they could be used for each.
Open or semi open back isn't an issue, I don't need noise cancellation and I think I'd prefer the more open soundstage. I don't need a microphone either, I have a dedicated desk mic.
I've been looking at the Beyerdynamic DT990 Pro's 250 Ohm. There a good all rounder according to Mad Envy's headphone guide, not sure if they'd necessarily need an amp/dac, but I doubt they'll be useable on PS4.
I've also been looking at the Hyper X Cloud 1 & 2's, they've have good reviews, would be compatible for both systems, have a microphone but I don't have to use it, they have 60 ohm impedance which might be a tad high for PS4 use? The 1's can be bought for just over £50 on the rainforest, I don't know if I'd need or use the 7.1 USB sound card on the 2's.
Has anyone got any experience with either of these, or recommendations for others? I'd really appreciate some advice, all the best and thanks in advance!
