Ok folks, I think I'm overcomplicating this way more than is necessary and I would be more than happy for that to be pointed out
Upshot is this... When I'm unable to use my speakers on my PC, I plug my Sennheiser HD 555's into the 3.5mm jack on the top of my case. Everything works fantastic, the PC picks up the headphones and switches to them as the output as appropriate.
The problem is volume. Anything that outputs sound needs to have the volume turned down as low as possible and of course this needs to be done via the various application or game menus. This then means it needs to be put back up when I'm done with the headphones.
Can anyone recommend something I can put between the PC and the headphones to give me 'in-line' volume control?
Thanks in advance for any advice!
.Upshot is this... When I'm unable to use my speakers on my PC, I plug my Sennheiser HD 555's into the 3.5mm jack on the top of my case. Everything works fantastic, the PC picks up the headphones and switches to them as the output as appropriate.
