Headphones Pc and ps4
25 Jan 2019
Goodnight everyone.
Could you recommend some headphones for Pc and Ps4 the use would be especially games. I would also like them to be comfortable
Until now I used Takstar Pro 82, when I bought them the Akg K702 were also recommended and I do not know anything about the current models
For now I don't want to buy any kind of amplifier. The pc motherboard is a x370 taichi
Thank you very much to all
If you're looking at the K702 or similar you will need something like a Soundblaster G6 to use it with PS4 and PC. Since you mentioned no amp then your options are limited for good sounding phones. The X2 or Koss Porta Pros for open headphones, not the best but they're easy to drive. Porta Pro has better timbre, more lively while X2 is more mid bassy, better depth perception for video games. Closed phone the DT770 32ohm is decent, AKG K371 is okay also.
The K701 & K702 when it comes to gaming are the best for open space emulation, subtle detail, competitive.
Thank you very much for the reply
if it were only for pc the k702 would work well without Dac? Or another headphone with a good quality only for pc
Yes it'll run fine off decent onboard.
Similar headphones would be
DT880
DT990
K702 has a bigger stage, quicker, snappier, more resolving of fine details. I will say if you prioritise gaming it's hard to beat the K701/702 but when you throw music into the mix they're not the best all-rounders, for that I'd say a DT880 would be better or even better a Verum or HD600/650.
