Headset issue
27 Mar 2016
Bristolian living in Swindon
Hi all
My missus plays PUBG with a bunch of friends daily and they were complaining about feedback/static coming from her mic, we went out midweek and bought a brand new headset and not exactly a cheap one, they are still complaining about the feedback/static coming through :confused:
What can be causing this?
Any help appreciated
Thank you
Does she use motherboard's integrated soundcard?
Those are known for having possibility of all kinds of interference issues.
And what's the precise problem?
Some static background noise/interference, or also listened sound leaking to mic recording?
Yeah plugged into the motherboard sound input output sockets...
It's hard to explain, kind of like someone rustling wrappers into the mic kind of noise
Is that continuous?
If not is there anything which has correlation with it, like moving the mouse or anything such.
Including also cable rubbing on clothes etc because of moving head.
Is that continuous?
It's not continuous noise only every now and then, apparently last night it picked it up on her mic even though she had it muted...
Unless Windows itself is doing something totally f'ed up, separate sound card should help.
