Headset recommendations
20 Oct 2005
Hey all, I was wondering if anyone can recommend a good headset for me, preferably for around £50 or less, though I can go above this. I like the sound and feel of the Medusas, however after having a second set break in the same way (plastic snapping just above the earpiece), I don't think it is a good idea to keep going with them. I require a headset which includes a microphone as I spend a lot of time using TeamSpeak while gaming, 5.1 would also be a strong preference. They will be used for movies and music as well as gaming. It would also be nice if I am unlikely to break them in less than a year.
i'm a total addict to quality sound and have 8 pairs of headphones at the moment and to be honest most 5.1 sets are ok but dont come close to a decent set of standard headphones,the best i've found if your into gaming is the steel sound v2 can hear a pin drop at 200 yards and they are pretty good for every day use listening to music etc,i have one set of the Medusa 5.1 Surround Sound Headphones and they are ok but like i said pay a little bit more a get a decent set of stanard phones
Thanks for the advice guys. Having already read a lot of the posts here I get the idea that general opinion is that headphones (without microphones) are far better than headsets. If anyone knows of any decent clip on or desk mounted microphone which will work well in noisy environments, such as lan parties, without having to carefully position them every time I want to speak, it would be appreciated.
Thanks for the suggestion of the steelsound v2s batchie. I have had a look at them and am not sure they will last any longer than the medusas, can you (or anyone else) comment on their build quality. To give you an idea of the level of wear they are likely to be in for, in the last 4 years I have broken 4 sets of Plantronics Audio 90s (no great loss) and 3 sets of Medusas (though one of these was by cutting through the cable, so not under what I consider my normal useage).
Headsets are just flimsy things; have never come across one that's lasted more than a year.
I've gone through 2 P90's and 2 Sennheisers and eventually caved in to peoples' recommendations to go the regular headphones route and am pleased so far.
p.s. I bought a pair of Sennheiser HD595's for £85 delivered.
