Greetings all.
I have had chronic issues with an old motherboard and have hence had to replace it with a new to me board.
Since moving to the new board, I have had real issues with cooling. I've previously used the Corsair H45 cooler for 8 months with temps where they need to be, but now with the same case / fan config and this new Mobo, my Core 0 is hitting 100c after a minute or two of Handbrake encoding.
I have cleaned and reapplied the paste numerous times and each time I remove, the spread on the CPU looks OK. Cores 2 & 3 (as labeled) are always OK but Core 0 followed closely by Core 1 are hot. I have tried adjusting voltage in an effort to reduce heat created and have also tried the CPU block installed at 90degrees, just in case of a flow issue.
I have checked that the pump FAN header is correctly fitted and the pump is always at max speed, with the CPU Opt speeding up as the temp peaks. All to no avail. I can feel the water moving, so I am sure that still works, but otherwise I am at a bit of a loss.
I feel a little like the block isn't really tight against the CPU and I am not sure if reapplying the back mount, has in some how reduced the overall depth, I kept the original sticky pad from first time around... Anyone got any smart ideas?
BTW I am using a brand new tube of ARCTIC MX-4 Edition 2019
Image for info.
Image for info.
