Some EVs have heat pump heaters, so a lot more efficient than an electric element.
Heatpumps are less efficient when it's very cold out. It's only really the ground sourced ones which are very efficient.
But 1kw is still 1kw
![Stick Out Tongue :P :P](/styles/default/xenforo/vbSmilies/Normal/tongue.gif)
or some of those wheatgerm/rice thingies you bung in the microwave for a minute.Access to a kettle where you work? If so, just full a hot water bottle maybe?
That's basically what I used to do when my dad had eye appointments at the hospital, as I never knew how long they'd be* it wasn't worth going home (30+ minutes each way), so I'd wrap up warm in the winter with some gloves, hat and a travel blanket and if need be run the engine with the heater on full for about 10-15 minutes every now and then.This. If your lunch is an hour long then 15 minutes running should keep you going. Just don't watch your average MPG drain away as you look at it![]()
Well 1kW heater making 1kW of heat is different to a heat pump turning 1kW into 1.5 - 2.5kW of heat...Heatpumps are less efficient when it's very cold out. It's only really the ground sourced ones which are very efficient.
But 1kw is still 1kw![]()
An EV might only be taking a few hundred watts to keep the cabin 'topped up' with heat, they really are very efficient now.
Makita make heated jackets which use their batteries; that's gotta be worth a look. The general idea is to heat the person not the space; and with a separate battery you can be sure you'll not be running your car battery down on the heater (of course you might still be using the stereo / etc)
Jon Champion was teasing Alan Shearer at the Aston Villa Leipzig Champions League game the other night about Shearer wearing a battery powered heated gilet. Lasts for 5 hours according to Shearer.Makita make heated jackets which use their batteries; that's gotta be worth a look. The general idea is to heat the person not the space; and with a separate battery you can be sure you'll not be running your car battery down on the heater (of course you might still be using the stereo / etc)
