hi all just wanderin if any of you have 480's sli at 2560 x 1600, as i was wandering if this heaven benchmark is any good, the reason i ask is that most of my games do not us close to 100% gpu, some games are using as little as 45 - 50% of the gpu's according to msi after burner, i am using drivers 260.52. although the heaven benchmark did use more but never went over 85% and dropped as low as 60%.
Unigine
Heaven Benchmark v2.1
FPS: 52.6
Scores: 1325
Min FPS: 5.2
Max FPS: 93.3
Hardware
Binary: Windows 32bit Visual C++ 1500 Release May 21 2010
Operating system: Windows 7 (build 7600) 64bit
CPU model: Intel(R) Core(TM) i7 CPU 930 @ 2.80GHz
CPU flags: 3780MHz MMX SSE SSE2 SSE3 SSSE3 SSE41 SSE42 HTT
GPU model: NVIDIA GeForce GTX 480 8.17.12.6052 1536Mb
Settings
Render: direct3d11
Mode: 2560x1600 fullscreen
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
Replication: disabled
Tessellation: normal
Unigine Corp. © 2005-2010
Unigine
FPS: 52.6
Scores: 1325
Min FPS: 5.2
Max FPS: 93.3
Hardware
Settings
Render: direct3d11
Shaders: high
Textures: high
Filter: trilinear
Anisotropy: 4x
Occlusion: enabled
Refraction: enabled
Volumetric: enabled
