Heavy CPU cooler
27 Feb 2009
Hinckley
Are there any risks of using a heavier cpu cooler? My friend purchased the thermalright 120 extreme, which i think is 800g without the fan, and thats pretty heavy.
I want to get a bigger zalman one but they weigh around 900g. I dont exactly move my system around much, except off the desk and onto the floor.
Am I just being paranoid?
I wouldnt worry about it tbh, ive used my TRUE black without issue (dual fans) the all copper version now is a different matter, it weighs about 2kg without a fan, btw id suggest the TRUE as its a signifigantly better cooler than the zalmans.
Motherboards these days are made to withstand even the heaviest of CPU coolers out there, otherwise you cudnt put 1 on. so your fine :D
if i transport my pc its always on its back (cpu cooler upwards)
to minimise chance of mobo damage
I remember my old Scyth Mugen 1kg with pushpin and I forgot 1 screw top left on the mobo... that was scary :D
Anyway you should be fine yeah :)
