Hello and my first newbie question.
28 Apr 2009
Fleetwood
Hello folks,
decided as I was going to dip a toe in the overclocking pond that it was worth while registering with these forums...:)
Now, I've recently bought the following;
Antec 900 case
650W Be Quiet Dark Power PRO PSU
6GB (3x2GB) Corsair XMS3 DDR3(PC3-12800 (1600MHz), 240 Pin, Non-ECC Unbuffered, CAS 9-9-9-24)
Noctua NH-U12P SE1366
Asus P6T SE, Intel X58
Intel Core i7 920, D0 (SLBEJ)
Now I'd like to overclock the 920, and was wondering how well the P6T will deal with this, and I noticed the board comes with some software that claims I can do voltage changes etc without needing to reboot... is this software any good? Is it going to make it easier for a newbie like me to get to grips with the arcane art of overclocking? *grin*
Also once I have the components in my new system, I will be transferring across my GTX295, I was assured the PSU would be fine for what I was sticking in the case, but happy to take onboard people's opinions..:)
Finally anyone has experience with this case, GFX card and the Notcua? Looks like it might be a bit tight.
During my research in to OCing, everything has pointed to the fact that OC programs are a no no, and generaly result in problems or instability.
I would suggest taking the extra time learning to use the BIOS for a safer overclock. Also learning how to do it will make it easier to understand why something goes wrong and if so what caused it and how to fix it.
Thanks for the advice - I do plan on pulling down as much info/links from the web I can before I do anything anyway... That was even if folks had said the software was fine as a front end to drive the process.
I'm not putting the rig together and transferring my Gfx card anyway unti I can get my hands on a Windows 7 RC on May 5th. Figured if I am going to build something new I may as well make the whole thing (including the O/S) new.
