- 18 Oct 2002
- Stone, Staffordshire
Ok I've got an old Dell Dimensions 4600 which has a P4 2.8Mhz processor and 1GB of ram. The machine is currently used for running my birdcam (search the forums if you wanna know) and I also use it to store my music, photos and docs on.
My mother passed away in February and that led to the realisation that I don't really have a very good filing method for my photos and if I where to lose the HD then they'd be gone.
What I'm looking for is a solution that covers most of the risk basis.
I had thought about buying an HP Proliant server (ML115) and replacing the dimension. I could then add extra disks in whatever configuration people thought was best!
Currently the Dimension only has 2 HD bays, and is fitted with a 200GB C: and 300GB U: drive (U for users data) and C: for the OS (XP) and birdcam captures.
Can I get an external solution to add to the Dimensions PC, would I be better off going with the HP and adding a few disks to Raid and Backup?
What solutions are recommended for long term archive and off site storage?
