- 25 Nov 2012
- Powys - UK
Hey everyone, I'm going to be building a machine, but I just wanted to check some stuff about drives.
What I'm going for is;
2 x 480GB SSDs in RAID 0 for Windows and my games
1 x 2TB as a standalone for all my other media
Then here is the question, I wanted to backup / mirror those 3 drives as a whole, onto a 3TB disk, so that for example it would be like a "RAID 0" (well reading the data from 2 places) between the 2TB and the 3TB because the 3TB would have all of the data on the 2TB, and then the 2 SSD's would be like a 3 way RAID 0 reading from the SSDs and the 3TB, but the thing I want to know, is firstly if that if this is possible, and if it is, will there be fault tolerance? IE, say 1 of the SSDs fails and the RAID 0 array is destroyed, will the 3TB still contain all of the data that was on the SSDs? Also the same with the 2TB drive?
I just wanted to see if I could tap into the unused read power of the 3TB drive, because otherwise I'll just use a portable 3TB hard disk and just backup both the 2TB and the RAID 0 SSD array onto that every night.
Thanks
-BrITBod
Thanks
-BrITBod
