Hi all, long time snapper short time DSLR user here with a few scrappy questions. I’ll probably have more as time goes on but at least now I’ll have a thread of my own rather than hijacking someone elses.
I have a soft spot for landscapes so I bought a Sigma 10-20mm – how essential would you say using a polarizing filter is? Also, would you leave a polarizing filter on as a lens protector or would you buy a UV filter for that purpose?
Does anyone use square/rectangular filters or do people just tend to stick with the screw on type? (I’m thinking more filters for filters now, and not about lens protection) Is one a compromise over the other?
My plan over the next 12 months or so was to replace the 18-55mm kit lens (I have a 500d) with the 18-55mm IS version, and then add the 55-250mm f4-5.6 IS. I’m now wondering whether to scrap that idea and just go for the EF 28-135mm f3.5/5.6 IS USM as a general purpose zoom. I used a compact camera for years that had an equivalent zoom end of 114mm which I was happy with so I’m thinking the 28-135mm might suit me better. My only hesitation is that it appears to be quite an old model – is it likely to be replaced soon or is it not really an issue? Good idea?
Thanks for reading, any insights/advice appreciated.
