Help after installing gtx780
16 Nov 2011
Hi I just installed my new evga gtx 780 classified today I'm having a slight problem with it but. On start up I get just a black screen with "b2" in the bottom right hand corner the screen stays like this for around 2 mins then windows boots up and everything is fine. Does anyone know why my pc would be doing this?
My spec is
Msi gd55 intel z68
I7 2600k
Gtx 780 classified
120gb ssd
500gb hdd
8th Kingston ram
Corsair enthusiast tx850w
Corsair h100
Asus xonar essence sound card
Hi,
in this case I would suggest to remove the overclock of the CPU if you are running one and also remove the soundcard and have a look if this error will still occur.
Have you already tried replaceing the card in the system and try also a different slot?
Please make also sure the power connectors are 100% connected.
Have you connected the PCI.E power to the card native of the power supply or do you use adapters for this?
