Help, AIO dosn't fit.
27 Jul 2006
Huddersfield
Hiya, the Arctic Liquid Freezer II 280 does not fit into the top of the Corsair Crystal 280x. I bought it with the intention of it going there and id have thought it would fit but its just too fat. The Radiator and fans are about 6mm too deep. It covers the Mini ITX standoffs.
Im trying to work out solutions.
I could fit the cooler in the front of the case, but i was hoping to have RGB fans there. I have 2 Phantek SK PWM DRBG 140mm fans could i just swap these out?
How much cooling power would i loose if i swapped the fans to thinner types?
This is to cool a Ryzen 7 5800x.
I think that overall moving the AIO to the front would possibly be the best option if thefan swap is possible, which id have to do for thinner fans anyway.
If its a no to these questions ill have to send the AIO back 8-(
Thanks in advance
Brian.
How deep is the radiator? I was able to fit a 280mm AIO when I had a Corsair 280X. (My AIO is/was a Kraken Z63) with standard 25mm fans. It was a squeeze, but possible.
I could fit the cooler in the front of the case, but i was hoping to have RGB fans there. I have 2 Phantek SK PWM DRBG 140mm fans could i just swap these out?.
Forget about RBG and put the cooler at the front.
The Arctic Freezer uses a thicker radiator than the usual ones, hence the performance. The 240 should be enough, the 360 desirable, but won't fit.
