[Help] - Best catalyst driver?
5 Dec 2010
I am using HD 4870 1GB
can anyone suggest catalyst driver which is stable, also very good performance
currently I am using 12.4, which is having a weird bug, when i select amd overdrive - then accept the agreement it just disappears
tried reinstalling + driver sweeper too.
still getting the same problem
The 12.3 drivers are pretty solid.
AMD Overdrive has many problems, it tries to clock cards which can't be clocked and its clock testing system is very poor (it doesn't apply enough load to the card).
MSI Afterburner is the way to go I believe, depending on your card though it may not be capable of being clocked since some manufacturers (XFX mainly) remove the ability to adjust card voltages.
By the way, OP, where did you update from??..
I always do that from my manufacturer's website.. Is the only that can provide you with the most stable version of drivers..
I'm on 12.4 now, very stable, as has been my previous versions since like forever..
With XFX or now Asus, I only download the driver from them..
And never got the latest one.. I give them at least a month to fix anything wrong (my GPU manufacturer)..
Best regards.. :)
Best regards.. :)
The manufacturer of your AMD graphics card won't be producing or fixing drivers.
They're providing the same drivers you can download directly from AMD.
