Help! best push pull config for my setup
18 Oct 2009
Wakefield
As you can see from the picture below my computer is in the corner of a room and i have a radiator on the back which pulls air in and 2 fans on the top which push out as well as 2 fans on the front which pull air in.
My current airflow must be horrible as my temps are always crazy high to the point of my card shutting down the display multiple times a week (even tried different gcards)
My current card is a reference card and it blows a lot of hot air out of the back and then my radiator is sucking it back in i think.
im using this case https://www.overclockers.co.uk/ocuk...p3NiMsMr5tBxBZGTso0cwRzhAIxfatYp7HhoCOAnw_wcB
if anybody could recommend a better airflow based on where my pc is located in my room that would be great.
Thanks in advance.
Stick it in the fridge? :)
Joking aside would not having the radiator pulling air in from the rear warm the case? Would not having the intakes at the front and exhaust through the back be better?
Definitely switch that rear fan so it is exhaust. Any drive cages that you can remove ? Is the pc free of dust ?
Also your case looks like the Enthoo Luxe and not the Enthoo Pro ?
ah i dont know to be honest i tho its a luxe but not as its got the black panel on the front but not sure if its pro or not.
also yeah im going to have a look at swapping it all around and see if the front drive bays are detachable.
