Man of Honour
- 17 Feb 2003
- Chelmsford
I'm using Nero to burn an ISO file to DVD but i get the following error:
Ignoring the message creates an empty disk.. Correction brings up a series of options ???
I tried using MagicISO but this also creates an empty disk (shows as just a CD in win exp).
Any ideas?
Foreign Image File..
The entered size does not correspond to the image length. The block size may be wrong. Do you want to correct the value or ignore the problem?
Any ideas?
