help changed monitor now wont detect! suse10.2
18 May 2003
hi i swapped from a iiyama vision master pro 454 to a samsung 226bw on dvi
all i get is the normal boot up then when it looks like X starts i get a blank screen.
tried running sax from command line. doesnt detect anything. just get blank screen.
any ideas how i can get it to work?
thanks Pete
I had the a similar problem with open suse10.2.After installing it a it just came up 'signal out of range' on my 15" lcd.Just gave up and went for Kubuntu with no problems at all.
