First things first - I didn’t install this, it was like this when I bought the property! I need to replace a kitchen sink tap but am struggling to undo the screw fittings between either the copper pipes and the tap or between the copper pipe and the fitting to the plastic pipe - attempting to unscrew either causes the plastic piping to simply rotate. I also tried to remove the plastic pipe from the 90deg fitting at the bottom but little success. Am I simply doing it wrong, is there a trick to unscrewing the fittings or is it rubbish and needs redoing from a pro plumber? Photo attached (edit: attached link to the image as I can’t seem to insert it)
https://1drv.ms/u/s!AvZMI0--dmE6hIxEc2YQU793iMkqdQ
